It is currently Thu Nov 05, 2026 11:46 am
 Post subject: Grade
PostPosted: Fri Sep 11, 2020 9:44 pm
I have a mixture of boards that are all from routers, cable boxes, & dvr’s. There are several makes and models but here are a few. Would these all qualify as peripheral or is there enough difference between them that some would grade out lower than peripheral?
 Post subject: Re: Grade
PostPosted: Fri Sep 11, 2020 10:04 pm
All peripheral
Remove wires and shields
PostPosted: Fri Sep 11, 2020 10:08 pm
Noted. Thank you!
PostPosted: Sat Sep 12, 2020 1:30 pm
Do I need to remove the shields even if there isn’t anything under them? The pictures are of the back side three identical boards just various stages of removing the shield
PostPosted: Sat Sep 12, 2020 1:45 pm
Bad
Acceptable
Your most awesome!
Pop the top and move on. If it’s not a cast iron or thick steel frame skeleton it’s acceptable.
Two issues with shields:
They add low value weight. In an industry of grams that’s important
Shields block the view. What if there’s a battery, or a shard from the All Spark.
Or a gold cap ceramic. We just don’t know.
PostPosted: Sat Sep 12, 2020 1:50 pm
Good to know! I have hundreds of these to go through. The top part comes off very easy, but the little bracket is headache!
And thanks for your explanation. It makes great sense
