It is currently Tue Mar 24, 2026 4:11 pm
 Post subject: Identifying boards
PostPosted: Wed Feb 24, 2021 12:36 am
I need help identifying theses boards
 Post subject: Re: Identifying boards
PostPosted: Wed Feb 24, 2021 7:09 pm
01 gold finger card with bracket
remove shield for something better
02 high peripheral
03 depends on back (as is high peripheral)
04 gold finger card, remove battery
05 high telco
06 probably high telco
07 low peripheral
08 low peripheral
09 hole telco
10 low peripheral
PostPosted: Thu Feb 25, 2021 1:30 am
I thought Wii boards went as Low Grade Telecom.
PostPosted: Thu Feb 25, 2021 1:46 am
New High Peripheral is higher than old Peripheral.
PostPosted: Thu Feb 25, 2021 10:45 am
I thought Peripheral has been at $2.25 for several months now. I have been keeping a spreadsheet for several years that has all the Boardsort payout rates in it. This allows me to enter in the weights of the boards that I have and then I get to see how many pounds of boards I have and how much I'm going to make off them. I just checked it and the price for Peripheral was $2.25 (I haven't gotten around to adding the Low Grade Peripheral category yet) and the file shows that it was last modified 1/28/21, 8 days before Chris added the Low Grade Peripheral category. I remember reading the announcement posted in the help forum and then checking the Payouts Rates. I saw the added Low Grade Peripheral category and saw that High Grade Peripheral was at $2.25, the same as the old Peripheral category.
PostPosted: Thu Feb 25, 2021 1:17 pm
You’re initial thought is probably correct.
Well, you are correct on price at the moment. ;)
It’s the class I was referring to.
I’m still get to the hang of i myself. And there’s likely to be some fluctuation over the next few weeks as BoardSort adjusts pricing now that high peripheral can move without concern for the former lowest end of the class.
I’m also completely doing most of this by memory. I don’t go digging into orders unless a situation such as this arises.
The Switch and U were telco. I have the Wii as both peripheral and low telco. So, let’s go low telco.
