It is currently Sun Nov 01, 2026 10:03 am
 Post subject: Board ID E26
PostPosted: Fri Feb 19, 2021 11:03 pm
More boards to grade. Thank you for the help
Number 1 in blank on the back side
Does Number 2 qualify as a gold finger board or is it Low Prep?
 Post subject: Re: Board ID E26
PostPosted: Sat Feb 20, 2021 1:11 am
Here's my guess:
1) Low Grade Peripheral
2) Low Grade Peripheral
3) Low Grade Peripheral
4) Low Grade Peripheral
PostPosted: Tue Mar 02, 2021 8:22 pm
What makes 1 and 4 Low Grade Peripheral and not High Grade Peripheral?
PostPosted: Wed Mar 03, 2021 11:20 pm
Not enough population in my opinion. But I could be totally wrong. They could both get High Grade Peripheral. Wait for Lostinlodos to reply.
PostPosted: Thu Mar 04, 2021 10:36 pm
1 is high peripheral. two sets of heavy gold pins, socketed quad, plated switches, high is safe here.
2 high peripheral. Heavy dual sided full face gold board. with edge connector. Here I'd say the zero population weight helps move it into the higher classing. and a few nice gold pins to help out.
3 doesn't have much going for it. on the bottom we have one tension/friction port. and one external (usb micro/mini?) port. on the top a single memory chip. a logic chip. and a controller. there's a LOT of board for just that. this is close. however I don't think it clears. low peripheral.
4 is high peripheral. only just clearing it in my book. the weight to value difference is there.
