PostPosted: Sat Apr 10, 2021 7:36 pm
Board #2 was some sort of gold traces for Maybe a keyboard
Board #1 was also some sort of keyboard I think
Board #3 appears to be some sort of mother board with Ram slot and onboard CPU or had an eprom.
There is also a close up of board #3
Board #4 (Sorry, I forgot to put the number by it) I am not sure what to classify it as. There are two boards in that pic.
What should they be identified as? Any help is deeply appreciated.
File comment: Some sort of keypad and they keys have been removed
File comment: Possible motherboard. Has some type of surface mount cpu and had an eprom and Ram slot
File comment: Last two boards I have no idea what to classify them as.
PostPosted: Sun Apr 11, 2021 7:47 pm
1: At least midgrade but I think it can make low peripheral
2: I have a bunch of boards similar to this that I need to ask about so can't help here.
3: Should easily clear high peripheral, which is better than the lowest grade mobos (might be able to go higher)
4: Larger board high peripheral; smaller, low peripheral
Just my guess though, if a more experienced person thinks otherwise go with their grade :)
PostPosted: Fri Apr 16, 2021 1:58 pm
Here's my guess:
1) Midgrade; might get upgraded to Low Grade Peripheral
2) Like marked141, I'm not sure about these.
3) High Grade Peripheral
4) Both Low Grade Peripheral
PostPosted: Tue Apr 27, 2021 4:40 pm
Chris says:
Boardsort wrote:
I would go Low Grade Peripheral on 1 and 2.
