It is currently Sun Sep 27, 2026 4:39 am
 Post subject: DVD SATA boards
PostPosted: Sat Jul 10, 2021 9:30 pm
Hey all, couldn't locate a previous question in search so here goes.
The payouts picture for CD-ROM boards shows an IDE connection. Would the boards from SATA dvd drives fall in that category or somewhere else on the list?
Bonus question: what about 3.5mm floppy drives?
 Post subject: Re: DVD SATA boards
PostPosted: Sun Jul 11, 2021 10:20 am
I have never had a problem with the interface type changing the grade of the board.
Let me see if I can find a post where Lostinlodos graded some CD boards for me cause I think that may help.
Floppy drives are usually peripheral if they have all the gold pins on them; that was before the high/low split on peripheral so hopefully high peripheral.
PostPosted: Sun Jul 11, 2021 10:29 am
Found it.
viewtopic.php?f=4&t=18961&hilit=+CD%2FDVD#p33568
So your compact drives from laptops will be the ones where you may not be able to get CD/DVD board grade because some of those boards don't have all the chips on one board.
You may also find CD/DVD class boards without a computer interface, there are examples of that in the second set of pictures I added to the above mentioned topic.
PostPosted: Sun Jul 11, 2021 11:53 am
Thank ya, sir. These are all full sized drives so that'll be easy enough.
PostPosted: Wed Jul 14, 2021 9:40 am
Thank you for this info! I have a few 'mini' DVD drive boards so I'm glad I saw this.
