It is currently Sun Sep 27, 2026 10:48 pm
 Post subject: A few Boards w/ Qs?
PostPosted: Fri Aug 06, 2021 8:37 am
Thinking these are probably all low grade, but just wanted to confirm (Front & Back Pics) . A couple quick questions:
1. Anything need to be removed? ex. are plastic screens ok?
2. Is it worth pulling off the IC Chips?
3. Should low and mid-grade be separated if they are currently paying the same rate?
- Much Appreciated. Thanks
 Post subject: Re: A few Boards w/ Qs?
PostPosted: Sat Aug 07, 2021 1:49 pm
They are low i think the going rate is around .50 a pound if you can find a boards buyer close to you if not you could pull the good chips and search the other components for copper and silver and maybe a hint of gold any relays on the boards may have silver or gold contacts that's my opinion
PostPosted: Sat Aug 07, 2021 3:35 pm
That style of screen should be okay to stay on the board, and if I've understood correctly, has some value of it's own that may help boards that are borderline on being upgraded.
