It is currently Tue Sep 29, 2026 10:49 am
 Post subject: Small boards to ID
PostPosted: Sat Aug 14, 2021 11:05 am
Few small boards to verify class. Thanks
 Post subject: Re: Small boards to ID
PostPosted: Sat Aug 14, 2021 12:44 pm
1. Low peripheral, maybe high peripheral
2. At least high telecom, maybe higher
3. Gold finger card
4. Low peripheral
5. Gold pin connector
6. Gold pin connector
Pipe wrench, separate pieces for heavy steel and cast iron (unless it is cast aluminum), otherwise you could throw it in with machinery cast whole. ;)
PostPosted: Sat Aug 14, 2021 10:15 pm
What is 2 & 3 out of?
They resemble some sort of RAM, but I don’t think thats what they are though.
If the back side of 3 is full of IC’s it may go high telco as well.
PostPosted: Mon Aug 16, 2021 11:07 am
2 appears to be an SSD. I asked Chris about one that I had (the same type as this one) and he said it was a Hard Drive Board. 3 is an Intel Optane memory card. 1 is Low Grade Peripheral as Chris has said that these boards go as Low Grade Peripheral.
