It is currently Tue Sep 29, 2026 10:16 pm
 Post subject: Need help with ID please
PostPosted: Tue Oct 26, 2021 11:55 am
Front and Back Pictures.
1B and 1C I am unsure if the back plate can be removed without destroying the board?
PostPosted: Tue Oct 26, 2021 10:16 pm
1A midgrade
1B low peripheral
1C low peripheral
1D high peripheral
1E high peripheral
1F high peripheral
1G low peripheral
1H not sure, at least low peripheral
PostPosted: Tue Oct 26, 2021 11:39 pm
B and C you're saying has a steel backing?
If they're glued (or other adhesive) you can probably pry the board off carefully. If they're riveted then I haven't found an easy way to remove boards without breaking them. Toss them in low grade if you don't want to mess with them.
H) low peripheral sounds right
PostPosted: Thu Oct 28, 2021 2:11 pm
Thanks for the input and suggestion :)
PostPosted: Thu Oct 28, 2021 11:11 pm
No problem!
I was thinking I remembered seeing a post from Lostinlodos regarding metal backings and after a bit of searching I found it here.
The entire thread is a good read if you're learning (as are many of Lost's posts) but the metal backing specifically is the 6th and 7th post in the thread.
