It is currently Fri Sep 25, 2026 2:13 am
 Post subject: identification help
PostPosted: Thu Apr 14, 2022 4:45 pm
Hi,
how would you grade these 2 boards please?
 Post subject: Re: identification help
PostPosted: Sat Apr 16, 2022 5:56 pm
Looks high peripheral to me.
B) The shield (steel cover) should be removed if you can and see if you can get that last screw too. Future reference, the ribbon cable end can probably stay but if you pull the two plastic tabs on either side it will let you pull the cable without cutting it.
PostPosted: Tue Apr 19, 2022 11:08 am
Thank you for the help
