It is currently Sun Sep 27, 2026 12:31 am
PostPosted: Fri May 06, 2022 11:32 am
The first pic is before I removed items not soldered on, and easily removable low value items.
The green plastic does not contain gold connectors. Please provide thoughts on the cleaned up board in pic 2.
Thank you
PostPosted: Sat May 07, 2022 7:00 pm
Those connectors are basic electrical connections you're looking at a plated brass or copper and maybe steel.
Cleaned I'm leaning high peripheral, don't think it can go higher.
If you have more of these I'm thinking don't clean off soldered components, just pull the green connectors and the battery and leave everything else. Should still clear high peripheral.
