It is currently Wed Aug 05, 2026 2:57 pm
 Post subject: Peripheral board grading
PostPosted: Sat Jul 02, 2022 6:48 pm
Wanted to verify on these.
#1 and 3 High Peripheral, a little unsure due to the gold plated button pads on the back of #1 and the gold pins on #3.
#2 Low grade, a little unsure due to the gold plated button pads here as well. Also, thoughts on it making High Peripheral assuming the 7 segment display comes off? (It just doesn't seem so to me.) I only ask because if it won't go that high it's in my low grade bin with the IC's stripped.
PostPosted: Sat Jul 02, 2022 9:54 pm
1 Should definitely be high peripheral
2 is probably an exception to the rule of brown boards being low; without being sure I'd probably stick it in low peripheral. The single digit display probably helps it go higher so no reason to remove (something Lostinlodos said awhile ago).
3 High peripheral is probably correct, though I'm not positive on that myself.
PostPosted: Sun Jul 03, 2022 7:49 pm
Appreciate the response marked. Good to know about the single digit displays, I wonder if that applies to multiple digit 7-segment displays or just the single 7-segment displays?
Maybe someone will respond to confirm on #2 and 3 since neither of us are positive. I'll likely do what you suggested though if no one else chimes in.
PostPosted: Sun Jul 03, 2022 9:17 pm
I'll try and see if I can't find a more informative breakdown from Lost on displays... Some displays add value, some don't.
PostPosted: Mon Jul 04, 2022 11:50 am
For reference, vacuum display:
viewtopic.php?f=4&t=7847&p=18824&hilit=display#p18824
Not the post I was looking for but also has the displays. This leads me to think your board is low peripheral since the board in this topic was high peripheral (just peripheral pre-split):
viewtopic.php?f=4&t=5081&p=15049&hilit=display#p15049
Another example:
viewtopic.php?f=4&t=3147&p=10204&hilit=display#p10204
PostPosted: Tue Jul 05, 2022 4:14 pm
I appreciate you checking further into that.
