PostPosted: Tue Sep 22, 2015 5:25 pm
Just a few items I have questions about. Thanks for your help!
File comment: Mid-grade or peripheral?
File comment: Midgrade or Low grade (since it has brown board)
File comment: Old hard drives, Can they be sold as HD's without boards?
File comment: Is this peripheral or better?
File comment: With these not having Chips on both sides are they still considered RAM? Also have a few silver ones with chips only on one side.
File comment: Are these worth anything?
PostPosted: Tue Sep 22, 2015 11:13 pm
In order
Mid grade
Low grade
Hard drive no board (better as Al#2 at a local yard)
Small socket
Gold ram
IC chip
PostPosted: Wed Sep 23, 2015 12:01 am
Just curious, what makes #4 a small socket?
PostPosted: Wed Sep 23, 2015 1:48 am
Soldered cpu on the motherboard
PostPosted: Wed Sep 23, 2015 12:36 pm
yes as long as you did not remove the ics it will go as gold ram
and the tin ones are the same way as ;long as you did not devalue them it will go as tim/silver/ram.
PostPosted: Wed Sep 23, 2015 12:51 pm
I'm going to Change my own statement on the hard drives.
Actually looking now while awake they may be magnesium...
Though not actually an alloy (duh)
If so bring them to a large yard that buys ewaste. You should get Al iso#12 alloy.
#12 alloy is a mix of Aluminium nickel and a special bronze made of copper magnesium and gold @ 1/20th rl-ml. It's commonly found in industrial laser scanners.
Try iscrapapp for local yards.
Al ay-12 is 68¢ this morning
This is something you'd be best local because of the weight
As an alternative you can strip old ones like these. If the platters are a brown colour the platters are a then-standard nickel disc with a gold layer. Not the micro sprayed platinum on aluminium
Gold platters run nickel rate ($4.15/lb) +20%-25%
PostPosted: Mon Oct 05, 2015 1:04 pm
Thanks for all the input. Unfortunately, The area in which I live does not have much as far as recycling centers. I am planning on taking another trip to Cleveland next week so I think I will just take them as HD w/o Boards.
PostPosted: Sat Oct 17, 2015 10:27 pm
Are these the brown disks we are referring to? I have placed a silver coloured one in the photo for comparison.
PostPosted: Sat Oct 17, 2015 11:41 pm
Yes that is them!
Nickel is running 3.80-4.10 during the week. Gold rate fell below 950 this week at one point.
The platters still run around $4/lb if they buy precious metals though.
Or acid bath them for nickel and gold split.
There's a thread on the gold refiners forum under escrap that's stickied for those platters. If you're into that sort of thing but there's not enough in just a handful to cover the cost of refining.
PostPosted: Sun Oct 18, 2015 12:56 am
Would you be able to direct me to the topic, I just tried searching but couldn't find the topic you re referring to.
