It is currently Thu Sep 10, 2026 8:13 pm
 Post subject: Pentium II
PostPosted: Wed Jul 06, 2022 10:35 pm
When sending these in:
Do you remove the plastic shell? If so, how?
What is the correct category?
Thank you,
Barre
 Post subject: Re: Pentium II
PostPosted: Wed Jul 06, 2022 11:28 pm
Yes. Look at the sides, the little clips on the side near the top. Just shove a small screwdriver or plastic opener gently into the tabs and twist.
PostPosted: Fri Jul 08, 2022 10:09 am
I like jackhammers for these.
PostPosted: Fri Jul 08, 2022 3:51 pm
Oh, thanks. I should probably mention that there are shells with rivets. HP, had a line. PIIIs with sinks.
Haven’t ever seen a riveted PII though.
For riveted plastic shells I break the tabs. Then use one of my trusty Gerbers to cut through the plastic around the the rivets.
Every scrapper should have a Gerber or a Jaguar.
Expensive, but definitely worth it. Especially with the (also expensive) blade chip warranty.
PostPosted: Fri Sep 15, 2023 8:59 am
That is the plastic front? What about the metal back to it?
PostPosted: Fri Sep 15, 2023 4:26 pm
I assume you found one with a heatsink back. It’s normally thermal past.
Look for screws or rivets first, then:
Just gently slide a screwdriver gently into each side between the processor board and the heatsink. Wiggle and a twist gently.
I suggest doing it from the top. The board is slightly thicker on the top vs bottom and you further protect the fingers.
