It is currently Thu Sep 10, 2026 11:57 am
PostPosted: Sat Sep 21, 2024 4:47 pm
I recently got a heap of old Cabletron networking blade switches, and each of the blades had either a socketed or soldered Intel i960 ceramic chip. I was informed that each of these chips will go as a 386/486. The socketed chips I already harvested, but when it comes to the soldered ones, what method would one use to remove those? I do have a 1500w heat gun and assorted screwdrivers available, but would I need additional tools to melt the solder more around the bottom of the board where the chip is soldered to remove the i960 chip?
PostPosted: Sat Sep 21, 2024 6:58 pm
Only the gold cap gold leg ceramics are 486.
Ceramic no cap gold pins are pentium/mac ceramic
No cap no pins are pinless cpu.
PostPosted: Mon Sep 23, 2024 12:03 pm
The heat gun might do it, try one and see how easy it comes off. Might need to brush the solder off the pins with a fine stainless brush. What are you going to do with the boards after you remove the chip? Probably easier to sell the whole board without extra work.
PostPosted: Mon Sep 23, 2024 7:07 pm
Bingo. Anything with an i960 soldered to it is probably worth more whole than removing chips.
