It is currently Thu Sep 10, 2026 9:59 am
 Post subject: AC adapters
PostPosted: Mon Sep 22, 2025 10:16 pm
Hello all, I am a pretty new scrapper, and have been doing lots of research on metals, e-waste, and the forums here. I don't think I've found any information relating to AC adapters, like those you'd see with laptops. The male USB-C would go into connector ends, the wire with everything cut off the ends is mixed wire, but what about the transformer/power brick? Does Boardsort accept the power bricks? See image for example.
 Post subject: Re: AC adapters
PostPosted: Tue Sep 23, 2025 7:43 am
I think it is just a power adapter, at 35 cents per pound with wire, 20 without wire. No "brick" category as such, but the brick is just an oversized AC adapter.
PostPosted: Mon Oct 20, 2025 10:34 pm
Boardsort buys them as AC adapter but if you're shipping you will probably lose money. You can crack them open for low grade boards or transformers. If you have a local yard, they often buy them as "wall warts".
PostPosted: Tue Mar 03, 2026 7:51 pm
More marketable on Ebay or Marketplace as what they are
That one looks like the newer usb-c charger
A wanted commodity
GL
