It is currently Sun Aug 02, 2026 9:56 pm
 Post subject: Elevator board 4
PostPosted: Tue Jan 27, 2026 6:00 pm
Is this high telecom?
Nothing on bottom.
 Post subject: Re: Elevator board 4
PostPosted: Tue Jan 27, 2026 8:00 pm
Not sure what those two Dale boxes are, they don't say anything about timing or clocks or battery do they? If not they're probably fine.
I'm thinking low Telco
PostPosted: Tue Jan 27, 2026 9:14 pm
The Dale components are labled L1 and L2. Those are inductors. Just can't get a good read on the identification numbers. Inductors being just coiled wire in those Dale packages. Made that way probably for stability through a wide range of dynamics. Temperature. Humidity. Stuff like that.
PostPosted: Tue Jan 27, 2026 9:22 pm
Yes Catwhisker, I just googled it . A ferrite inductor.
Thanks,
LindyLou
PostPosted: Tue Jan 27, 2026 9:27 pm
You can get a lot of board identification using Google Lense also. It helps getting you a bit closer to an evaluation.
PostPosted: Wed Jan 28, 2026 9:12 am
Yeah, I figured they weren't batteries since there were two and it appeared they were labeled with Ls. But the picture was just blurry enough that I wasn't certain. ¯\_(ツ)_/¯
