It is currently Wed Apr 01, 2026 7:54 pm
 Post subject: CPU chip type?
PostPosted: Sat Feb 14, 2026 6:46 pm
I don't see this chip in the examples on boardsort.
 Post subject: Re: CPU chip type?
PostPosted: Sat Feb 14, 2026 6:48 pm
Good day. This one is a P4/Green Fiber With Metal.
If you go to the price sheet and look at the example picture, the picture is comparable
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Sat Feb 14, 2026 7:35 pm
Thank you! I thought it might be that one, but the picture looks a little different. Thanks for the confirmation!
PostPosted: Fri Mar 13, 2026 2:09 pm
thats as P4/Green Fiber With Metal. its literally a p4
PostPosted: Wed Apr 01, 2026 6:08 am
Interesting could you tell me would legs and no legs make them different?
PostPosted: Wed Apr 01, 2026 9:23 am
yes, the CPU without pins if it has the IHS AKA the chunk of nickle plated copper goes as a "No Pin CPU". Also some very old CPUs have aluminum IHS but that rare, sometimes those chips are worth pulling the IHS off if you have the right tools as they are so light and it would upgrade class the CPU can be scrapped as, just be sure its not a soldered IHS chip.
PostPosted: Wed Apr 01, 2026 9:51 am
are these the chisel hammer tools one
PostPosted: Wed Apr 01, 2026 9:52 am
and these are from 06 and 2010
PostPosted: Wed Apr 01, 2026 10:04 am
I don't want to call them older because I'm from 85 and I'd like to think I'm not being called older lol
PostPosted: Wed Apr 01, 2026 10:28 am
no, it could work but you are likely to crack/shatter the die, and if its a soldered chip you will shatter the die, a deliding tool or a thin razer blade and heat are the right tools. That is outside the AMD k6 CPUs, you can pry those IHS off with a thin flat head screw driver, same with the NVIDIA FX chips too.
As for the age of the chips, the first you posted is a P4 from around 2002, the second photo can be anything from 2004 to today, looks like a AMD64 or newer chip and the other one might be a lga775 CPU. The older CPUs I was talking about with the aluminum IHS are from around 1997 to 2000 ish so about 25-30 years old and rather old by tech terms, Think AMD k6 and some PIII CPU's
