It is currently Wed Apr 29, 2026 8:32 pm
 Post subject: AMD Chip (What is it)
PostPosted: Wed Jan 21, 2026 3:42 pm
What have an AMD Ryzen 5 3400G and i'm leaning toward AMD Ceramic Aluminum Top K6. Am i on the dot? Theres no other categories for AMD besides AMD Ceramic No Metal.
Ryan Keller
Keller's Custom Services
PostPosted: Wed Jan 21, 2026 4:48 pm
Does that have pins? Or is it smooth. Based on that question. It will be P4/green fiber with metal. Or. No Pin CPU.
Hopefully someone else will post.
PostPosted: Wed Jan 21, 2026 5:41 pm
This one has pins sticking up, not smooth like the other one.
Ryan Keller
PostPosted: Wed Jan 21, 2026 9:10 pm
Ceramic has a pink-purple color typically. That has a green fiber board.
So green fiber with pins
PostPosted: Sun Feb 01, 2026 2:54 pm
to be absolutely clear. P4 fiber with metal. Green fiber with pins can't have the metal cap.
PostPosted: Fri Mar 13, 2026 3:04 pm
yep . P4 fiber with metal. I send ryzen pro CPUs in all the time as P4 fiber with metal, you can thank covid era supply chain protection for that. Believe it or not the ryzen G line used by OEMs have a piece of code written into the CPU/motherboard buy the OEM, after the code is written into the CPU a set of write fuses inside the CPU is blown tying the CPU it to that OEM and you can't use them in different OEM branded motherboards. Not a big deal but a lot of the time that code goes haywire and bricks the CPU.
