It is currently Mon May 25, 2026 6:08 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 07, 2026 12:16 am
CRTs contain Cadmium , Barium, Lead and Mercury. PCBs, about the same, especially depending on specifics and application. All of which are HIGHLY poisonous to humans.
If you don't know or are not educated yourself; You must be careful or you will harm yourself.
PostPosted: Tue Apr 07, 2026 12:19 am
I believe they didn't completely phase out using these materials til 2010 and before. Be careful
PostPosted: Tue Apr 07, 2026 9:14 am
They were phased out in around 72... out side of lead and the lead used was very very small only found in the glass near the neck and barium withc was only used to flush out a CRT of loose glass and other gasses when replacing the tube. You don't know what you are talking about, I used to replace the tubes on CRTs regularly witch included heating the glass up with a torch. the only harmful parts are the stuff found on/in the PCB and the glass if shattered, maybe the fly back if you go poking it wile it's powered on. And no the lead is not for blocking X rays, its for deflection. assuming you are not dealing with a pre 72ish B&W CRT, those are the ones with all the harmful crap in them. Next thing you're going to say PSUs have 10s of 1000s of volts in them when powered off.
PostPosted: Tue Apr 07, 2026 11:58 am
Looks like Thomas Electronics still uses barium https://www.thomaselectronics.com/crt-r ... endations/ and says it's common practice. Barium Oxide, BaO, baria, is harmful to skin and can cause irritation if swallowed (I doubt anyone is swallowing bits of broken CRTs though). :P Large enough quantities can lead to death.
I misspoke when I said phosphorous, it's phosphors which contain any number of compounds:
https://www.phosphor-technology.com/crt-phosphors/ not that phosphorus doesn't have is own health risks in quantity.
So...the point isn't that you can't possibly handle a CRT or dismantle it or even break it. You just have to be aware that there are some risks, however slight. Also, Lostinlodos can probably expound on this better than I can, having this site hosted by a business, there's probably a level of liability involved that they don't want to be responsible for. Just because I have handled CRTs and removed everything from a bulb and broken the vacuum doesn't mean Boardsort wants a conversation about it (at the very least without acknowledging there are risks) cause there's inevitably someone who will read it and blame Boardsort after they go around bashing in CRTs carelessly and end up finding one that implodes just right to throw glass back at them or who decides to break them all in their basement and when they go to clean up, breath all the dust with various compounds for lack of a respirator.
Again, if you don't know what you're doing or how to handle certain things, anything can be dangerous.
PostPosted: Tue Apr 07, 2026 1:42 pm
This thread has gone on a tangent. My original question was about LCDs. Why are we talking about CRTs?
PostPosted: Tue Apr 07, 2026 2:39 pm
See this
Spence1015 wrote:
Every state has a recycle program or dump around the area you have to discover or learn about.
IMO, if you are not a larger scale operation or E-waste management, do not break down monitors or TVs. You will be left with an amount of waste you cannot handle or it will go places it shouldn't and not be taken care of correctly. Plastics, screens, etcetera.
As Marked141 stated, Goodwill and your local town or state "clean-ups" ( which usually occur once or twice a year for cities) have a spring or summer routine clean up for an electronic drop-off. Free***
PostPosted: Tue Apr 07, 2026 2:40 pm
>What to do with lcds -jbrown
>>don't break them down to a point where you can't get rid of them -Spence
>>>my waste company will even take crts, don't give me grief about them -Austin
>>>>anything handled improperly can be dangerous but we're talking lcds, don't get cut on those either -me
Tangent achieved...¯\_(ツ)_/¯
PostPosted: Fri May 08, 2026 3:40 pm
All crt units contain dangerous concerns.
From toxic chemicals at any and every CRT has regardless of what the specific toxin is.
To the risk of implosion blowback
To the very real concern of live electric in a non-discharged television. Those capacitors stay alive for a very long time.
The bottom line that was made here is if you don’t know what you’re doing (education not YouTube) don’t mess with them
PostPosted: Tue May 12, 2026 3:52 pm
Didn't see this mentioned but my father's township and my township have a specific building where you can drop off hazardous E-Waste.
What we do is take a few over at a time as they employees of the township check IDs and verify you aren't from a different township.
As long as you don't abuse this they are fine with a few trips a month. I took a half dozen laptops carcasses and I have 5 more ready to go when I head that way.
