It is currently Fri Apr 10, 2026 9:14 pm
 Post subject: Cleanup / Category
PostPosted: Fri Apr 10, 2026 1:55 am
Looking for some help with these boards in terms of what I should remove from them if anything to get the best category for each, & what that category is. Also, if I were to just leave them as is, what would they currently go as?
All 3 of these boards came out of one server drawer (case/box).
The first 2 pictures are of the same board (front/back), the 3rd & 4th photo are separate boards & I didn't take pics of the backs of them since they are pretty basic backs imo.
Thanks in advance
 Post subject: Re: Cleanup / Category
PostPosted: Fri Apr 10, 2026 8:07 am
1(2). Likely high Telco, picture is a bit blurry but I assume those IC looking things are all just that and probably gold plated pins in the connectors.
3. Generally speaking you should remove any wires from any board, looks like there's 3 on this one.
3&4. I don't see anything that would necessitate this being in midgrade but it's either low or mid grade, as is I'd toss in low. You could choose to remove the copper if you want.
PostPosted: Fri Apr 10, 2026 9:53 am
I can't make it all out as the photos are to small, the top might be telco, I'm leaning towards low teclo, high peripheral.
The rest look like low grade boards.
You will make more money leaving the lower 2 boards alone outside of the wire that needs removed from the one.
