It is currently Thu Jun 18, 2026 7:59 am
 Post subject: Flat ware ?
PostPosted: Fri Apr 24, 2026 10:53 am
I get a lot of silver plated Flat ware but IDK if its something boardsort, the talk in the other post spoke of it being copper/brass that's plated but all the silver plate I find is not brass or if it is brass is very high zinc content brass. Sorry for the crappy photos, my phone is old and I had a hard time getting it to focus. I can tell it has a thick silver plating, does the base mete matter at all? most everything I get is from WM Rogers and I know Rogers mostly made silver plate, just wanted to make sure it counts as silver plated if its not yellow brass or copper under neath
 Post subject: Re: Flat ware ?
PostPosted: Tue Apr 28, 2026 11:57 am
austin86 wrote:
…most everything I get is from WM Rogers and I know Rogers mostly made silver plate…
That’s actually very incorrect. Most of the women on my mother’s side have collected this brand back to the early years.
Their sterling silver is marked as 925 always
Their plate is clearly marked as plate
If it says silver or is missing the silver or the above marks, it’s coin silver. The alloy varies by set buts it’s between 45 and 60 percent silver.
PostPosted: Tue Apr 28, 2026 12:28 pm
Here is an example
PostPosted: Tue Apr 28, 2026 3:33 pm
different WM Rogers. There like what 50 different companies by the same name. the stuff I get is WM rogers mfg co and none of my silver buyer will touch is because its ether not silver or plated. I was wanting to know if it mattered if it the base mettle was brass, copper, nickle or something else.
