It is currently Tue May 05, 2026 9:54 am
 Post subject: Some more boards
PostPosted: Mon May 04, 2026 2:31 pm
A few more boards I could use help with grading. I'll be sure to remove the bits of wires from them before packing them.
 Post subject: Re: Some more boards
PostPosted: Mon May 04, 2026 2:38 pm
1/2/3 remove steel strip and wire, all peripheral high grade
4 peripheral low maybe. high if there is gold pins in the connectors
5 glue on the chip, if you can remove it all peripheral high.
6 peripheral low
7 cd rom board
8 peripheral high
PostPosted: Mon May 04, 2026 3:05 pm
Thanks for the reply! A few questions:
For board 4, could it bump up to high peripheral if I removed the AV and coax ports? Doesn't look like there are gold pins unfortunately.
For boards 6, 7, and 8, the bottom pic is the same 3 boards as the pic above it. I see you had 2 separate classifications for them, not sure if you thought they were different boards in the bottom pic. Would you still go with 6 - low peripheral, 7 - cd rom, and 8 - high peripheral?
PostPosted: Mon May 04, 2026 3:21 pm
you could remove the AV ports for high, its borderline high as it is
