It is currently Thu May 07, 2026 2:53 pm
PostPosted: Sat Oct 25, 2025 3:53 pm
I've been sorting my circuit boards, and I've gotten down to the last few I can't quite figure out what they would be graded as. Any assistance would be appreciated!
PostPosted: Sun Nov 02, 2025 6:43 pm
Bumping
PostPosted: Sun Nov 02, 2025 9:40 pm
This is a lot all at once and easy for people to put off replying due to the number of boards to look at. Lost has provided guidelines for posting you may want to read through. viewtopic.php?f=4&t=19156
PostPosted: Tue May 05, 2026 10:35 pm
image 1-4 high peripheral
image 5 low peripheral, maybe high if the ends have gold pins
image 6 remove the motor coil and steel back and it's low peripheral
image 7, 1 and 2 are high peripheral, 3 i can't make out, 4 is a laptop gold finger card, 5 is low peripheral
8 high peripheral
9 hrs call, technically a gfc but there hardly any gold fingers, maybe high peripheral
10-11 high peripheral
12 low peripheral
13 idk
14. DO NOT F'ING SCRAP THAT, put the steel bracket back on it and reinstall the IC you removed from the socket and sell it for a few 100 dollars on ebay, it's a sound blaster AWE32, highly desirable sound card for older PCs that people will fight over
15 remove steel high peripheral
16 all high peripheral
17 1 high peripheral 2 remove steel covers and repost a photo, 3 low peripheral
PostPosted: Wed May 06, 2026 7:51 am
I’ll come back later today but had to say omfg :bow down:
It’s a real one in the wild!
That’s the 4th most expensive sound card on the retro market If it works!!!!! and the 5th if doa!
PostPosted: Wed May 06, 2026 9:10 am
The diamond video card depends on the other side as is would be peripheral but if enough on the other side may elevate to gfc
PostPosted: Wed May 06, 2026 9:28 am
IDK if its the 4th but its in the top 10 for sure. Funny thing, the CT3670 model of the sound blaster 32 was better in every way, cheaper, easier to find and with ram did everything the awe32 did and more. It even has a SB64 chip on it with DSP 4.16 and on board ram making it a true SB64 and the only one with simm slots and not the dumb ram card. But everyone seems to forget that card.
PostPosted: Wed May 06, 2026 1:41 pm
I think what sets these a32s apart is the VC instruction chip (top left) that was pulled from later sound blaster cards for legal reasons. I don’t know the full story beyond the various half-truths and myths, but I can see the VC (literally for very creative) chip top left that’s missing from later cards.
The one you speak of I believe is the one that had the proprietary synth chips. Rather than the licensed ones?
Others that regularly make the higher prices (like op) are cards with onboard controllers that are flashable (uv or electrically), like the Audio Science and and SKS, or have hard coded sound font libraries, like the Emu card pair
PostPosted: Wed May 06, 2026 2:55 pm
it did not have a true OPL3 chip, not sure if it was licensed or not but it sounds good. The output on the card is a lot cleaner then a lot of other SBs of the age too. IMO if you don't have the ram card for a AWE64 gold its the card to get for dos gaming PCs, assuming you can't get a EWS64 ether and assuming you don't want a modern card like the pico GUS or Orpheus
