It is currently Thu May 14, 2026 11:50 am
 Post subject: BOARDerline Boards
PostPosted: Tue May 12, 2026 3:29 pm
On the fence about where these boards would be classed. Top board feels low peripheral but could possibly be high peripheral because the chips are big?
And the lower one seems junky, though I am not sure if resistors are really heavy junk, and the capacitors are numerous but small. Could this one be low peripheral, or is it mid grade?
 Post subject: Re: BOARDerline Boards
PostPosted: Tue May 12, 2026 3:47 pm
I believe you have socketed ICs that you would remove on the top board.
For me I would probably throw them in High Peripheral but again I am still learning. I would wait for more seasoned veterans to chime in.
PostPosted: Wed May 13, 2026 10:41 am
Partially Harvest Boards / Missing BGA/Flatpack/Corner Tabs
Have you read the above post? Its on the Boardsort site. In the Annoucement section. On top of the page.
The What it is? Identification page.
PostPosted: Wed May 13, 2026 11:24 am
top is high peripheral the bottom is low peripheral
PostPosted: Wed May 13, 2026 4:03 pm
Hello. Austin86? What's your response and evaluations if cutthescrap follows dhill_cb7 response on removing IC's? For High Peripheral on the top board. My suggestion is. DO NOT REMOVE THE ICS. But. Thats just me.
PostPosted: Thu May 14, 2026 9:16 am
He might as well take all the ICs off at that point and send the board in as a mid grade board. I'D leave them on too.
Removing ICs is a fine art, on some boards you can remove a IC or two and stay in the same class, on others you can't remove any without down grading the board, if OP were to remove the socketed ICs on this board your getting into low peripheral and getting close to mid grade territory.
Here is a good example of a board were one could get away with taking a IC off and not risk down grading the board.
viewtopic.php?f=4&t=25180
If I had that board I would remove the gold tab flat pack and send the board in as high peripheral.
Looking at cutthescrap's board there is a lot of empty space in the board so removing the ICs will downgrade it.
