It is currently Sun May 24, 2026 9:12 pm
 Post subject: Flexible pcb as antennae
PostPosted: Thu May 14, 2026 1:51 pm
These are from hotspots but know some phones make use of similar manufacturing, basically a flexible circuit board wrapped around plastic to act as an antennae. Has gold contacts but also a lot of plastic.
Thoughts on best way to scrap? I'm not planning on peeling the pcb off.
PostPosted: Thu May 14, 2026 2:06 pm
IDK if you can send them in as is so I would put it in a bag or wrap it with a rag and bust the plastic off with a hammer, then sent the pins in as gold plated pins or connector ends depending on whats inside.
I do the same thing with the brass pins in old connectors too, if the plastic is not brittle let it rot in the sun and wack it with a hammer.
PostPosted: Thu May 14, 2026 2:37 pm
Hmm... I'm not sure I was clear.
Is flexible circuit board glued on plastic with 2-3 gold contacts where the tracing is exposed.
Pretty sure a hammer would shred it and is still have to peel the bits off. Not sure the gold is even worth it.
This doesn't even have to go to go to Boardsort if it's not circuit board-y enough. I'm just not sure if there's even a copper bearing material grade this could go in.
PostPosted: Thu May 14, 2026 3:20 pm
ahh I see now. lol. IDK if they would take it. I would email Chris.
