It is currently Thu Nov 05, 2026 4:35 am
PostPosted: Thu May 14, 2026 2:50 pm
Got two heatsinks that I pulled the copper out of already but I'm left with fairly heavy fins that bend like aluminum, are slightly pulled toward a neodymium magnet and the exposed metal after breaking is white.
Thoughts on what it is made of?
PostPosted: Thu May 14, 2026 2:55 pm
For what it's worth, there is solder still on it, though I keep going back and forth in my mind as to whether there could possibly be enough to make them feel as heavy as they do.
PostPosted: Thu May 14, 2026 4:07 pm
Short a grinder for spark testing, I can't imagine stainless would bend as easily as this did and it only took a couple bends to break
PostPosted: Thu May 14, 2026 10:50 pm
My suggestion is to cut or pull a tiny piece from the fins.
Then test the piece alone with the magnet.
Aluminium sinks are rarely 100% clean.
Usually there’s some nickel content. And if it’s over 1-3% it will pull.
I just had an argument over a bracelet at a trusted buyer this week when it stuck to the magnet: sure I was wrong till I put $20 on the line. Test it with the xrf scanner. Said if I’m wrong I’ll pay you $20 (their non-customer scan test price) and if I’m right you pay me $50 for the $$30 bracelet
My 925 silver bracelet was 075 nickel.
The fastest test for low cost is a grinder spark test.
PostPosted: Thu May 14, 2026 11:51 pm
Nickel seems to get into everything now. Ive had aluminum brass and even copper give a slight pull to a hard drive magnet. Some brass was actually giving a fairly strong pull but we cut it up and ground on it. Nothing but brass but must of had a lot of nickel in it!
PostPosted: Fri May 15, 2026 6:59 am
Exactly what I did.
I can't remember now the why behind it but brass can become magnetic in certain applications.
I'll see if I can remember to take a piece home to grind.
PostPosted: Fri May 15, 2026 9:43 am
I love how quotes is just a formatting thing and you can change them :P
Half that quote was gemcutter
