It is currently Mon Sep 28, 2026 3:24 am
PostPosted: Fri May 22, 2026 12:37 am
There definitely appears to be a gold center contact in these coax ports, but they're entirely made of what I believe is brass, so I'm wondering if that would disqualify them from a connector end category?
Please let me know what you think.
PostPosted: Sat May 23, 2026 6:35 am
Can you remove the gold pin? Then you have a simple answer. Gold Pin category. And brass. Though I am thinking the housing is just some type of cast. Not solid brass.
You could just hit it with a hammer and chisel. See what's going on with the piece.
PostPosted: Sat May 23, 2026 10:58 am
I'm guessing the housing is die cast or zinc (or similar)
Should be okay in connector ends, if you have quite a few you can see how easy one is to open up and see if you want to pull all of them out not.
