It is currently Thu Nov 05, 2026 8:03 am
 Post subject: Server fans
PostPosted: Mon Jun 01, 2026 11:37 am
For regular scrapping, would server fans (or other computer fans) go as a motor or is there too much plastic?
 Post subject: Re: Server fans
PostPosted: Mon Jun 01, 2026 12:52 pm
Cut the fins off you get motor
Leave the fins in CBM in most places
PostPosted: Mon Jun 01, 2026 1:23 pm
austin86 wrote:
CBM?
Copper bearing material
PostPosted: Mon Jun 01, 2026 3:09 pm
Same thing
Quote:
Sent from your deceased grandmother's rotary phone
Twilight zone
PostPosted: Mon Jun 01, 2026 3:34 pm
There was an episode I had seen as a kid on syndication that I know is 100% real and know was twilight zone about some old lady talking to someone on a phone but I’ve never found it again in any package or on streaming.
Ended with the shot of the phone cable stuck on a grave.
One of those lost episode things I guess.
I know it’s not false memory because I watched it with my mother and grandmother at my grandmothers house and they both remembered it
PostPosted: Mon Jun 01, 2026 3:54 pm
Finally thanks
PostPosted: Mon Jun 01, 2026 9:50 pm
I assume by cut the fins you mean I have to also cut the entire surrounding box material? Probably not worth that level of hassle of so.
PostPosted: Tue Jun 02, 2026 8:15 am
yeah you want to get rid of the bulk of the plastic so the frame and fins cut back as close to the actual motor.
What's annoying is it's not always just a simple plastic "clip" holding the drive shaft. Sometimes it's a skinny metal o-ring with such good tolerance that a hammer is all that's left to disassemble with. Which isn't a problem if you don't mind breaking everything :D
PostPosted: Tue Jun 02, 2026 2:14 pm
Yes.
PostPosted: Tue Jun 02, 2026 2:15 pm
Some companies actually have a fan rate though so ask.
Usually it would cover everything from a tiny processor fan to a household box fan to industrial air blowers.
