It is currently Fri Jun 05, 2026 4:25 pm
PostPosted: Sun Dec 18, 2022 4:21 pm
Please help Identify & Grade Thank You !! D.E.F. !
PostPosted: Fri Jun 05, 2026 10:10 am
All High Peripheral.
PostPosted: Fri Jun 05, 2026 10:28 am
not so sure with E and F, I think e came form a floppy drive, a 5 1/4" one so it could go as CD drive but with the gold edge and all the chops, the gold pins I feel like it could be a telco board. F IDK, looks a lot like a motherboard, it has a agp slot, PCIX? and a cpu socket, is that a apple g4 motherboard ??? would those go as a large socket board ?
PostPosted: Fri Jun 05, 2026 11:30 am
It is an apple mobo. Says apple 2002 in the top right.
PostPosted: Fri Jun 05, 2026 11:50 am
Lost has graded 5.25" floppies from clean gfc to Telco in the past.
viewtopic.php?f=4&t=3135&p=10165&hilit=Floppy#p10165
viewtopic.php?f=4&t=1322&p=4471&hilit=Floppy#p4471
PostPosted: Fri Jun 05, 2026 12:00 pm
*puts on on man glasses* well ill be you're right!!
PostPosted: Fri Jun 05, 2026 12:03 pm
marked141 wrote:
Floppy drives boards can be real toss up, some are mid grade, some are telco, some looks to be peripheral. I sent more then a few 3 1/2 drive boards as CD drive boards too. I think we need to take floppy boards on a case by case biases.
PostPosted: Fri Jun 05, 2026 12:16 pm
3.5" are fairly standard. All gold pins still present, high peripheral. Otherwise midgrade
5.25" will likely vary more but intact should grade fairly well compared to smaller drives.
PostPosted: Fri Jun 05, 2026 2:29 pm
Not really all that standard, some have only 1 or 2 tinny ICs and the rest is junk. Others are covered in ICs and you can find ones in between too. I pulled one away back that no ICs on it at all. But the better populated ones with gold pins can be sent in as CD boards all day long, I been sending them as CD since I started selling to board sort and never once had a down grade.
