It is currently Wed Sep 16, 2026 1:40 am
PostPosted: Thu Oct 31, 2024 12:33 pm
Broken Game Cam boards - anything good ?
PostPosted: Tue Jun 23, 2026 7:51 am
Late reply.
Pic 147 is low peripheral as it stands. You can upgrade this to high peripheral by removing the large plastic section. I personally would remove the capacitors as my yards buy them as dirty aluminum. I can also fit more boards into a box without bulky capacitors in the way. Your call though.
Pic 138 needs to have the shield removed so we can see what is under it. Considering visible gold this would be low peripheral if you did not remove the cover. Take some angle pliers and pull up the cover. Should come off with some effort.
Pic 706 are there any gold pin connectors in those housings? Also is there a memory card in the slots? You would need to remove those before sending. This one might squeeze into high peripheral.
Pic 644 is high peripheral. I would not do anything to that one. Looks good as it is.
Pic 546 seems to be a combination of the 644 and 138.
Pic 336 is a closeup of 138.
