It is currently Wed Jul 01, 2026 6:12 pm
PostPosted: Mon Jun 29, 2026 9:01 pm
Curious on these boards since they are kind of unique and I am still learning. I am thinking all peripheral high grade but am not 100% sure. The smaller boards came from a pager and VHF emergency response radio. Regarding the larger board (A), will the vga and dvi ports demote it? The bottom right (G) the metallic stuff is steel so would that make that mid grade? Thanks for any help!
PostPosted: Tue Jun 30, 2026 11:20 am
A/C/E shouldn't have any trouble going high peripheral, ports are fine
B is at least midgrade but unsure if it can get low peripheral
D seems more likely to be low peripheral
F I'm leaning low peripheral
G, the steel fencing and solder is fairly substantial from that angle, if you can remove most of the steel high peripheral should be possible. As is, can probably low peripheral
PostPosted: Wed Jul 01, 2026 4:39 pm
Thank you, Marked, for the info!
