It is currently Fri Jun 12, 2026 8:01 pm
 Post subject: What grade?
PostPosted: Wed Apr 09, 2014 9:43 am
Hey all, I'm close to sending a large lot to boardsort. These are bins full of boards harvested from (mostly) Dell servers. What grade do I call these?
I just don't want to call these one thing, get paid then learn they're another.
Thanks!
 Post subject: Re: What grade?
PostPosted: Wed Apr 09, 2014 10:02 pm
No way to tell from the pictures. There looks to be a few different grades in there. Would be good to look at the current payout page and read the descriptions of the different grades.
PostPosted: Thu Apr 10, 2014 3:32 pm
It appears you have peripheral boards, but as scob89 said, it would be best if you used the resources available here to sort your load, then get weights of each type, then send it in. If you have a piece that you are unsure of, photograph it front and back and post it here and either boardsort or one of the other forum members will look at it and determine the grade.
You can also use the e-scrap gallery to help you get started with your sorting.
http://boardsort.com/cpg15x/
PostPosted: Fri Apr 11, 2014 1:10 am
The red circles are boards that look like power supply boards, copper chokes and can capacators might cause a down grade, as they mentioned the e-scrap gallery will help you sort for the best payout,
PostPosted: Fri Apr 11, 2014 8:47 am
Excellent, all of your replies have been VERY helpful. Thanks so much!
