It is currently Wed Sep 16, 2026 8:33 am
 Post subject: Help grade please
PostPosted: Sat Jul 11, 2026 12:36 pm
Best guess on grades here? Both from tv
I know to pull the heat sink off, anything else to pull?
Thanks
 Post subject: Re: Help grade please
PostPosted: Sat Jul 11, 2026 1:33 pm
Long thin are most likely high peripheral
Larger board you should remove the heatsink at mininum. On the wire connectors you cut, there's a small clip (tab/lever) that if you push on it the whole thing will pull out without cutting. Don't know if that's easier but thought I'd mention it. As far as grade, as is, it's at least low peripheral, I'm thinking you'd need the transformer off too to get high peripheral.
Do be sure to show the entire board if you want the most accurate assessment by others. The long boards could very well be a different grade because we don't know how much more board is there or what's on it.
PostPosted: Sat Jul 11, 2026 2:08 pm
What you see for the thins ones is what there is. They are just very slightly tucked under the big one.
Ill take the transformer off also, thx
PostPosted: Sat Jul 11, 2026 7:26 pm
Cool, wasn't sure so wanted to point out out just in case.
PostPosted: Mon Jul 13, 2026 12:36 pm
Generally, TVs have a low grade board (brown/tan and I’ve seen white as well). A high grade peripheral (yours is high if you remove the transformer) and 2-3 high grade strips like you have.
