It is currently Tue Nov 03, 2026 1:25 am
 Post subject: removing chips
PostPosted: Wed Jul 15, 2026 12:30 am
vintage avionics generally solder both sides with hi-temp hi-silver solder. the boards tend to burn before solder melts. what is the magic to remove chips. not HCL. prefer to not damage or shorten legs.
chillin at Scrooge McDuck's place dreamin bout gold
and out of work comedian :lol:
 Post subject: Re: removing chips
PostPosted: Wed Jul 15, 2026 5:18 am
As far as scrap, expect the chips to get a downgrade if there's solder on the legs. I do not know what they would go down to, just don't expect gold cap gold leg IC.
PostPosted: Thu Jul 16, 2026 12:34 am
sorry. i would call balony. solder is removed in refining process. been there done that.
any downgrade would be disingenuous.
say 1/8'' thru board and backside x 40 pins is about 5'' longer, with thicker than normal gold plating. total 15'' on white chips and 7'' on purple. tiny weight, but adds up for already light weight chips. am i wrong. might pay big, but such light weight. AND vintage avionics solder, more silver balance solder weight. am i wrong?
just sayin....
PostPosted: Thu Jul 16, 2026 2:06 am
over an hour of showing ai the error of each possible way of removing those chips, here is its final answer.
PostPosted: Thu Jul 16, 2026 2:33 am
my conclusion is top high paid boards. this being a sample of the boards i have. and a sample of ceramic ic's of the era. i busted them open to reveal precious metals in every one. zoom in and look. pretty golden tiddies to me.
ANYONE HEARD FROM BOARDSORT/CHRIS YET
Askin for a friend....
PostPosted: Thu Jul 16, 2026 9:24 am
I'm simply relaying the information that has been provided in the past regarding solder on pins/legs. Chris and his team are ultimately the ones who make the call though.
Chris has responded in two parts of the forum now. I was able to connect with another person within the company and relay our concern for his wellbeing as well as a number of us being unable to reach him.
PostPosted: Thu Jul 16, 2026 3:01 pm
i understand the solder story, hense, reality is a higher class of board when containing such chips. if i ever get thru to chris, i could ask. these vintage avionics wernt meant to come apart at 30,000 feet nor here on the ground. each hole is lined w/copper connecting top to bottom and often kink in the legs making them almost impossible to remove. i went toe to toe debunking every way ai said to remove until it gave up. only full board to refiner made any sense.
also,
read my post; Post subject: Chris is alive and well
carry on!
PostPosted: Sat Jul 18, 2026 9:10 pm
i will try my darndest to contact this next week.
but... check out below.
legs worth more than cap.
both gold cap n legs worth more than individuals combined???
just sayin
PostPosted: Sat Jul 18, 2026 11:37 pm
Yes, that top price is what I was referring to when I said don't expect gold cap gold leg if you remove them.
Will it drop to the just gold cap rate? I would think not but again that's not my call, I would think somewhere between. ¯\_(ツ)_/¯
Since there are multiple chips on that one board, you could take just one off if you're able to, then you can take pictures of the end result to post here (or email Chris) so that he has as much info as possible when making a call on grade when you contact him. Then depending on what he says you can use the weight of the chip and board to work out whether to remove the rest or not. And feel free to let us know what Chris says.
