It is currently Tue Aug 25, 2026 12:48 am
 Post subject: Laser diodes
PostPosted: Wed Aug 05, 2026 8:48 pm
Are these good for anything? Have a ton of them.
 Post subject: Re: Laser diodes
PostPosted: Thu Aug 06, 2026 12:12 am
Not sure on the wired bit, the board will depend on further processing. Boardsort doesn't like glass so really the whole plastic but should come off but you could potentially just remove the mirror(s and any other glass I can't see). Best case without disassembly I'd guess midgrade but maybe closer to the take apart category. If you take one apart and post pictures of just the board we can give you an idea on J that
PostPosted: Thu Aug 06, 2026 12:21 am
Thanks - but was asking about the laser diode specifically. Included the full assembly photo just in case the context was helpful.
PostPosted: Thu Aug 06, 2026 3:51 pm
Really not sure on the diode as is. Probably need it out of the housing.
PostPosted: Thu Aug 06, 2026 4:32 pm
Incidentally here’s what’s under the camera
PostPosted: Fri Aug 07, 2026 5:59 pm
Grade on the board now that the camera is removed? Looks like the chip/sensor has gold wires
PostPosted: Sat Aug 08, 2026 5:16 pm
I'm leaning low peripheral but not 100%, might nudge up to high. I was trying to find a post about similar boards with that type of ceramic chip/sensor but couldn't locate it.
PostPosted: Sat Aug 08, 2026 7:22 pm
I’d put it with my high end peripheral. Here is my logic. If it has a ceramic DLP chip worth three times more than an IC chip. It would be like having three IC chips on the board giving me a good gold/fiber ratio enough to put it in that category. Food for thought.
