It is currently Thu Oct 01, 2026 7:31 pm
 Post subject: Custom Blank PCBs
PostPosted: Thu Oct 01, 2026 2:11 pm
I am trying to determine what category blank custom PCBs might fit into.
They are blank 6 layer construction, copper layers are 1/2 oz with 1/2oz plating.
What category are these?
As a follow up, in addition to blanks, I have many that are populated and assembled into a device, shown in the image.
What category would an assembled unit fall into? They are a handheld device with and aluminum casing that I assume is similar to the "digital Camera" category.
I am new and wondering if it would be best to take the time to dissemble the devices and scrap the aluminum, then send in the populated boards to board sort.
Thanks with your patience from someone new!
 Post subject: Re: Custom Blank PCBs
PostPosted: Thu Oct 01, 2026 2:38 pm
Try to swing back to this later but here's a primer on blanks:
viewtopic.php?f=3&t=19554&p=35735&hilit=Blank#p35735
PostPosted: Thu Oct 01, 2026 4:12 pm
So to know for sure you'll likely need to talk to Chris/Boardsort, but these look like they might be into a peripheral class. Boardsort may not even want them though, again need Chris' input.
There might be resell value but that's out of my league, Lost might be able to provide more info on that.
The unit, I'm not sure but I'd think digital camera would be worse case scenario as those have lots of plastics vs yours with an aluminum housing (unless there's a ton of junk in it too?). If you have a substantial amount you could take one apart and figure the price and use that as a basis for how much you'd need to make from the whole unit to be worth it.
PostPosted: Thu Oct 01, 2026 5:49 pm
Thank you I appreciate the response! I will look into taking units apart and determining worth/time
