It is currently Fri Sep 25, 2026 1:02 am
 Post subject: ibm power 5 cpu board
PostPosted: Mon Apr 07, 2014 9:52 pm
unsure if these little tabs are gold plated and what spec.
they were pulled from a 7038-6m2 1.2ghz
PostPosted: Tue Apr 08, 2014 7:16 am
They appear to be. To be more accurate in grading the board, would it be possible to see another photo with the heat sinks removed?
PostPosted: Sun Apr 13, 2014 2:13 pm
here are some more pics
PostPosted: Sun Apr 13, 2014 4:30 pm
It appears that there are IC chips or CPU chips on those heatsinks. One appears to be ceramic, so it would pay well once separated from the heatsink. A screwdriver and a little bit of elbow grease should separate the two. I'm guessing by the size of the one chip the board is large socket, but to be 100% accurate in grading, we would need to see the board in its entirety with the heatsinks removed. If unsure of the IC chips removed, post a photo of those once you get the heatsinks removed.
PostPosted: Mon Apr 14, 2014 1:38 pm
the cpus are white ceramic type material.
I only have two boards
PostPosted: Mon Apr 14, 2014 3:14 pm
Hello xkmail,
We would buy those boards as Telecom grade but those whopper heatsinks and metal casing must be removed.
Thank you for the look!
