PostPosted: Thu Jun 23, 2016 9:31 am
These came from CRTs and Power Supplies. Are they something that Boardsort will take? And if so, what grade? Do I need to do anything else to break them down further?
PostPosted: Thu Jun 23, 2016 10:11 am
They're all low grade. You can pull aluminium and copper for local as they're worth more than the boards.
PostPosted: Thu Jun 23, 2016 3:39 pm
Pulling the aluminum and copper was fairly difficult on the one power supply I started with... do you have any ideas/suggestions for how to do this?
PostPosted: Fri Jun 24, 2016 12:46 pm
pry off the ic chip on the bottom tv board...boardsort buys them by the pound
PostPosted: Fri Jun 24, 2016 12:55 pm
I'll do a full and complete breakdown to bare board this weekend of a standard power supply and maybe a tv for my what's inside it.
PostPosted: Fri Jun 24, 2016 3:10 pm
Yep got a tv so I'll post full breakdowns to bare boards this weekend.
PostPosted: Mon Jun 27, 2016 12:16 pm
I'm a little behind schedule but they are on the list. ;)
PostPosted: Tue Jun 28, 2016 9:57 pm
Mike the Scrapper had done a video a year or two ago where he breaks down low grade boards for metal recovery. On most of what you have here, pliers and elbow grease will be your best tools. When I do low grade boards, I usually go for the transformers with the most weight or exposed copper. Exposed copper transformers then can be further broken down to recover the wire which can go as #2 copper.
PostPosted: Tue Jun 28, 2016 10:08 pm
I've got the boards out. Pics within 24 hours.
