It is currently Tue Jun 04, 2024 4:22 am
PostPosted: Tue Nov 21, 2017 2:43 pm
What grade?
PostPosted: Tue Nov 21, 2017 3:42 pm
mid-grade assuming they are green on both sides.
probably not worth sending in, alot of guys strip the large components off and bring them to a local scrap yard since postage eats most of the profits.
PostPosted: Tue Nov 21, 2017 3:59 pm
sound advice ^
yes copper
and extruded aluminum are both worth more than midgrade-lowgrade boards must of the time in that way..
if you go that way you can also strip of the ics to sell here per lb...
PostPosted: Tue Nov 21, 2017 4:51 pm
Thanks! Yes they are green on both sides. Pulling the copper, IC's, and aluminum then throwing the board in the "midgrade" gaylord. I come across something new every piece I open up...granted I'm new at this so it doesn't take much.
PostPosted: Tue Nov 21, 2017 5:53 pm
There’s a lot of heavy copper breakage on that. My suggestion is pull the aluminium heat sink. Sell the heatsink for AL #1 (most heat sinks even when painted will get #1 due to the clean Al source), and the whole board as #2 CBM to a local yard.
PostPosted: Tue Nov 21, 2017 7:35 pm
lostinlodos wrote:
There’s a lot of heavy copper breakage on that. My suggestion is pull the aluminium heat sink. Sell the heatsink for AL #1 (most heat sinks even when painted will get #1 due to the clean Al source), and the hold board as #2 CBM to a local yard.
yeah what mls26cwru and lost [in a confusing way said ] i need a lostinlodos to evil thesaurus sometimes ..
anyway locally is the way to go with that i would strip all that sell as clean copper since its 2.44-2.65 lb for me as well as the heatsink ,and those 2 capacitor in dirty aluminium (check your scarp yard 1st) the wires .the things holding the heatsink on will be brass or copper sometimes steel ect ect
PostPosted: Tue Nov 21, 2017 8:58 pm
Sorry, working on getting less short hand-y. Lol
