It is currently Tue Jun 04, 2024 6:37 am
 Post subject: attached i486's
PostPosted: Thu Jul 19, 2018 12:20 pm
 Post subject: Re: attached i486's
PostPosted: Thu Jul 19, 2018 3:59 pm
Do I leave them attached? What category would they fall into? If they should be removed, how do you do it?
PostPosted: Sun Jul 22, 2018 12:23 am
large socket motherboard
telco (you can probably remove the 386 and 387 chips for 386/486 class) those ceramics are are most likely in RC-PGA sockets. BUT, that's not a guarantee. If you see black plastic between the ceramic and the green they're socketed and can be removed
Large socket motherboard, remove the 486
RC-PGA sockets are very strong grip sockets. Use a Number 1 or Number 2 screwdriver initially to GENTLY gently loosen the corners, cross from each other. eventually you'll be able to pull them up by hand then.
Top board, most/all soldered, forget it.
middle, see in line statement
bottom. definitely socketed
