It is currently Wed Jun 05, 2024 4:51 pm
 Post subject: Sparks processers
PostPosted: Tue Dec 03, 2019 2:27 pm
Should I remove from board? How does the heat sink come off.
 Post subject: Re: Sparks processers
PostPosted: Tue Dec 03, 2019 2:40 pm
Apple cpu (PDB processor)
Don’t remove anything or the price drops on everything
PostPosted: Tue Dec 03, 2019 4:16 pm
Define everything. Board? Processor? Gold pin? IC?
PostPosted: Tue Dec 03, 2019 4:42 pm
The chips are all soldered so the processors would be pinless.
The board would be peripheral.
Remove the memory and controllers as well the board would be midgrade.
Removing the pins only drops the board to peripheral.
Remove everything you have a green but low grade board, some ICs, pinless processors, copper baring material, some stuff Chris doesn’t buy that a local yard would consider mixed shred... like the aluminium capacitors.
The best value you can get (for most people anyway) is as a whole board. I’ve pulled enough of these pdb style processor boards to have tried every striping combination. Over all the highest value was as a single whole board.
PostPosted: Tue Dec 03, 2019 4:46 pm
Thank you
