It is currently Tue Jun 04, 2024 8:28 am
 Post subject: What are these?
PostPosted: Sat Jan 11, 2020 4:16 pm
Not sure what these items are, Wire wrap pin board, CRT Yokes,Hard Drive puncher or bent no board. Also does Boardsort buy laptop hard drives ?
 Post subject: Re: What are these?
PostPosted: Sat Jan 11, 2020 6:47 pm
The photos in the payout chart should help. Just hover over the item line or click it.
Wire wrap board is a very specific subset of pin boards. If you’re not sure if it’s wire wrap board it’s probably not. (They will always upgrade it on reception if it is). Generally pin board is pin board and wire wrap board is instantly recognisable from the rest in person for those trained to know the difference.
CRT Yokes are the copper, rounded pyramid blocks around a crt unit (tube TVs and monitors)
A punched hard drive has one or more holes in it that are not part of a design. Created by a hammer and punch, or chisel, a gun shot, a press, or other method. Bent is just what it says. A hard drive that has been bent, or folded. Often by vice or bending press.
Both situations are used by the to destroy hard drives and protect data security. Doing so makes data recovery much more difficult; but not impossible.
Yes, boardsort buys laptop hard drives.
