It all varies based on what's actually present on the board. If you have a fairly good mix of power components such as transistors, resistors, capacitors, and transformers, along with the IC chips, it will go as peripheral. If you have several flatpack or soldered CPU chips along with something on the board indicating that a heatsink was used to cool the chip, that will get you the upgrade to small socket motherboard. The printer boards listed here also contain RAM slots, so that will also factor into grading.
_________________ kgryczan Forum Moderator
