It is currently Wed Jun 05, 2024 6:40 am
PostPosted: Thu Apr 21, 2022 5:55 pm
computer power supply's out of their metal case with/without wire harness...does Boardsort take these as low grade ps?
How about power supplies from monitors, low grade ps?
I couldn't find anything in discussion groups that really fit my situation
thank you
Craig
PostPosted: Thu Apr 21, 2022 5:59 pm
Bare boards without the tail are low grade.
PostPosted: Wed Apr 27, 2022 11:54 am
Will they be taken with the heatsinks still attached or do those need to be removed first? I suppose as long as the aluminum price is the same or higher than low grade PCB that wouldn't really be much of an issue?
PostPosted: Wed Apr 27, 2022 5:40 pm
A typical desktop PSU comes in a steel box with wires coming out one end. This is a PSU with wire.
If you cut the wire off, or if you happen to have a modular PSU with the cables unplugged, this is a PSU without wire.
If you open up the steel box and remove the circuit board this will be a steel box and, more likely than not, a low grade circuit board. Meaning you can remove pretty much what you want if you think it's worth your time to do so.
I'm at a point where I'm not usually taking PSUs apart. If I see copper or brass heatsinks inside, maybe.
PostPosted: Thu Apr 28, 2022 12:30 am
Well out. I unscrew one side of a power supply box and bend it up to see inside. If I see copper I’m going in. No copper? Not worth it for me.
What’s worth it to you is up to you.
I can pull a PS apart in about 30 seconds. And decrease the value for my local yard payout.
I can totally strip one bare in 5-10 minutes depending on age and design. Giving me a few bucks most, in component scrap.
Ultimately copper heatainks and spacers make it worthwhile for myself. And you can clean a rack mount backplane PS board enough to reach low peripheral. Anything else goes as electrical scrap.
