It is currently Fri Nov 06, 2026 10:39 pm
 Post subject: Board category?
PostPosted: Tue Jan 13, 2026 11:44 pm
This came out of some medical equipment. When I do an AI search for classification, it tells me both high grade and mid grade. It had that little chip on it as well. It has lots of gold pins on the sides
 Post subject: Re: Board category?
PostPosted: Thu Jan 15, 2026 12:21 pm
Put the IC back in its socket. Then submit as High Telecom.
PostPosted: Thu Jan 15, 2026 12:32 pm
Thank you for your time and feedback. It’s greatly appreciated
PostPosted: Thu Jan 15, 2026 12:42 pm
Should have posted in the What it is? Identification Forum. You would have gotten a more timely response.
PostPosted: Thu Jan 15, 2026 3:04 pm
Picture of the front side of the CPU?
It will go either as P4/Green fiber w metal
or with no metal top, Green/Brown no metal
Bit more profit then High Tel
PostPosted: Thu Jan 15, 2026 3:39 pm
Another concern of this board would be the BenchMarq IC; if I'm not mistaken they are the same as Dallas switches. Works as a real time clock or CMOS
PostPosted: Thu Jan 15, 2026 3:49 pm
Spence1015 is right. I looked up the BenchMarq IC. It has an "onboard" battery. The IC must be removed before selling to boardsort.
PostPosted: Thu Jan 15, 2026 5:21 pm
I think I fell asleep before I could point out the battery...whoops.
I wasn't sure enough on the IC to say anything, I feel it's likely closer to ICs in value. Gold pins on their own would potentially lower the value from that. Even if just IC value that's better than high Telco leaving it on the board.
It kinda reminds me of an IC I had once on a laptop mobo but it was soldered on so I didn't pull it.
