It is currently Mon Sep 28, 2026 11:32 am
PostPosted: Wed May 20, 2026 4:01 pm
Please help. Not sure exactly what to classify these as. New to this. Thanks in advance
Thanks a ton in advance for any help/info/advice. VERY new to this realm. Be kind. Just trying to learn like everyone else.
PostPosted: Wed May 20, 2026 5:10 pm
At least high Telco. Not sure if it can get a better rate. If nobody else can offer a definitive assessment I'd email Chris to see how he'd take it
PostPosted: Thu May 21, 2026 2:15 pm
austin86 wrote:
Its ram, but!!! it does not fall into any of the ram scrap category as far as I know.
Is it RAM or some kind of old style L2 cache module? Not that it effects the scrap category, but I'm just wondering. The only info I can see on it it the HP logo.
Do you have just one or several? If you have several I would send Chris an email because there's a big difference between high grade telecom and RAM.
PostPosted: Thu May 21, 2026 6:56 pm
The chips on the board are without a doubt. RAM chips.
So. It is a RAM board. But. No gold fingers.
What to do? Just like it is. I would submit High Telecom.
But. If one would cut the connector off. Put that into Connector Ends. Then submit the board as Trimmed RAM. At $19 50 a lb. As opposed to High Telecom at $11.00 a lb. Might be a better move. Just an e-scrapper thought.
Unless you have a large quanity. My suggestion would probably be unproductive. But. It could make a difference. Again in large quanities.
PostPosted: Thu May 21, 2026 8:07 pm
For what it's worth I had a similar situation:
viewtopic.php?f=4&t=19292&p=34856#p34856
Granted prices were flip flopped at the time for high Telco and fingerless... I would not trim the connector off unless you contact Chris and ask first.
PostPosted: Fri May 22, 2026 9:45 am
Maybe this is one of my overly cautious moments but I still think if you want to go that route you need to verify with Boardsort first as it's not a standard form for what's considered RAM. Removing the connector may end up taking off more value than leaving it or may not even make what's left a better grade.
