It is currently Mon Sep 28, 2026 4:10 pm
 Post subject: What would this go as ?
PostPosted: Thu Mar 22, 2018 5:58 am
Can someone help me grade these please
PostPosted: Thu Mar 22, 2018 9:55 am
I’m sure one of the other guys can be a lot more help but I do know that
5th from the top the boards out of the flat screen are Peripheral
6th from the top looks telecom
9th from the top is Peripheral
11th looks mid-grade
PostPosted: Thu Mar 22, 2018 8:35 pm
01)peripheral
02)peripheral: it was a Cd/dvd board but it’s cut up.
03)gold pins peripheral, not gold plated pins mid grade
04)telco
05)peripheral
06)telco
07)mid grade if cpu is missing, peripheral if it’s there, can’t quite tell for sure
08)peripheral
09)peripheral
10)peripheral
11)peripheral
12)low grade
13)peripheral
14)mid grade
15)mid grade
16)peripheral
17)mid grade
18)telco
19)peripheral
20)peripheral unless it’s a glass board, which would be mid grade
21)gold pin connectors
22)mid grade
23)peripheral
24)peripheral
25)peripheral
26)peripheral
You’re better off not cutting parts out of boards. Eg all those cd/dvd boards are worth less now, as peripheral boards and gold pin connectors.
That one board I’ve seen as glass and a thin plastic before as well as the standard pcb so if it’s glass or plastic it will be mid grade
PostPosted: Thu Mar 22, 2018 10:36 pm
Thank you for that information
