It is currently Sat Nov 07, 2026 6:54 pm
PostPosted: Sat Dec 17, 2016 11:09 pm
Just wanted to see if this is a telecomm board, and if yes does it need to be cleaned of the large pin ports, and the small heat sinks.
PostPosted: Sun Dec 18, 2016 1:03 am
leave the ports, take the aluminum heat-sinks off...they should just pull of with a pair of channel locks.
yes, the board is telecom.
PostPosted: Sun Dec 18, 2016 3:31 am
MLS, unless I'm blind there are no sinks. There's two sets of ports and the led display
No sinks
But yes telco
Never mind I'm blind.
PostPosted: Sun Dec 18, 2016 10:53 am
Thank you!
I cleaned off the heat sinks, but a few ic's were stuck and came off with the heatsink. Is it ok to just glue the ic's back to the board? Is there a preferred method?
Which leads me to a whole other depopulate question which I will start a new thread for.
PostPosted: Sun Dec 18, 2016 12:46 pm
as long as its only a couple, you will be fine... they know and understand that sometime heat-sinks will take the chip with them.
I would just throw the loose ic chips with your other chips and send them in whenever its convenient.
PostPosted: Sun Dec 18, 2016 4:00 pm
Stuck chipped heatsink ICs I tend to toss into peripheral or midgrade depending on the IC size.
