It is currently Fri Aug 28, 2026 11:42 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 30, 2016 9:57 pm
cosmetal wrote:
More Telco?
Are these 2 the same board? if so it's a gold capped chip board.
PostPosted: Fri Dec 30, 2016 10:04 pm
Yes
Top pic is the rear - bottom pic is the front
PostPosted: Fri Dec 30, 2016 10:16 pm
It's hard to see in the pic, but, there also is a bunch of gold capped ??? identified as TP19, TP20, etc. next to the chips and throughout the board.
PostPosted: Fri Dec 30, 2016 10:20 pm
Those are test points. Still a gold capped chip board
PostPosted: Fri Dec 30, 2016 11:20 pm
Thanks for your help
PostPosted: Sat Dec 31, 2016 1:13 am
Ah, there it is!
Gold cap chip board
PostPosted: Sat Dec 31, 2016 1:14 am
Make sure you remove any that Are socketed. 8080/8086 CPUs!
PostPosted: Sat Dec 31, 2016 2:13 pm
I wish.
The Intel i960 CPU along with the four gold capped:
AD676JD
0327
D45830
Analog Devices ICs
are soldered in.
I think I'll put it on display next to the Mothra heatsink . . .
PostPosted: Sun Jan 01, 2017 2:53 am
