It is currently Sat Nov 07, 2026 6:53 pm
 Post subject: Stripping the boards?
PostPosted: Wed Jan 04, 2017 1:03 pm
Do the connectors (some with gold pins), I.C's and capacitors need to be removed before sending? I've attached some of the board pics. Thank you!
PostPosted: Wed Jan 04, 2017 4:00 pm
midgrade
Peripheral (or better depending on flip side)
Questionable: normally midgrade but if those are gold pin the rules in place put it as peripheral
PostPosted: Wed Jan 04, 2017 5:22 pm
Thought I would add, usually removing anything downgrades the board quickly to either midgrade or worse.
PostPosted: Wed Jan 04, 2017 5:31 pm
Yes NEVER remove ICs or gold pins
Thanks; was on autopilot in answering without reading
